Results 1 to 8 of 8
Thread: Clear P0401 with Blocker Plate and tire size questions.
    Oct 2006
    Default Clear P0401 with Blocker Plate and tire size questions.
    Downloaded my 06 LBZ program (OS 12616698).
    I removed the "Fingerstick" but retained the EGR blocker plate, so I modifed the following values to clear the P0401 CEL:
    B1501 Disable
    B1502 100
    B1503 140
    B1504 -40
    B1505 -1
    B1506 100
    Changed H0136 value to 587 for 315-10-17 tires.
    Am I on the right track so far?
    My ultimate plans are for a good gas milage tow tune. (I also noticed that in many EFILive tune "librarys" sites there are very few 12616698 files).
    Doing this in "baby steps"...
    Ray
    Aug 2010
    Hello Ray,
    I don’t do diesel tuning, so I can’t help out with your first question.
    Regarding changes in tire size – the software uses the tire diameter to calculate necessary changes. If you go to the Speedometer segment, open the parameters category, you will see the Speedo Calculator button.
    Open the Speedo Calculator and input your current tire diameter. The software will automatically recalculate tire circumference, revs per mile (probably won’t match the manufacturer’s value), and pulses per mile. After you click on the “apply” button, you will notice H0136 has been updated to a new value.
    Save the changes. You can then go back into the Speedo Calculator to use the “Shift Point Correction” utility – to update transmission values based on your new tires.
    Regards,
    Taz
    Oct 2006
    Thank you Taz on the info on the tire sizing. Didn't realize their was a “Shift Point Correction” utility.
    Member jay p's Avatar
    Dec 2005
    Here is a script for turning off egr on an LBZ. The speedo calculator doesn't seem to work right on my LBZ. It says I should use 637 r/mile and factory is 652r/mile (for 265s). 652 is right on with my GPS.
    noegr.txt
    Jay
    2019 Sierra 6.2l
    2017 2500HD L5P
    2010 2500HD LMM (sold)
    2005 Harley Ultra Classic
    Mar 2008
    I had to fine tune my speedo too using GPS
    06 GMC 2500 CCSB SLT LBZ 4X4
    These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
    Jan 2008
    Quote Originally Posted by Dozerboy View Post
    +1 here
    Oct 2006
    That is my plan today. Borrowing wifes GPS to verify speed.
    Drove truck around yesterday, the P0401 code is gone. Now I need to bring the shift point lower (that will be another thread). Thanks for all the help.
    Ray
    2006 Silverado "Grey Ghost" 2500HD LBZ LT/CC/SB
    6" Rough Country Lift Kit, 315/70/17 BFG AT, Raceline Renegade 8, RCX 2" Wheel Spacers and RCX Tie Rod Sleeves
    EFI Live with EGR Blocker
    Banks Ram-Air/Super Scoop
    Mag-Hytec Differential Cover
    5" Magnaflow Cat-Back with 4" MBRP Front Pipe
    Edge Insight w/pod
    I have to use 2 sizes lower (about 2.5%) to get correct readings. It has always been an issue with 06-on. I have to think that it is an easy software adjustment for the next update.
    Custom Tuning Services
  1. How to change tire size on LL8?
    By dirt_track_racer_81 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: October 29th, 2010, 05:55 AM
  2. Speedo Recalc for New Tire Size
    By CVs06Tahr in forum General (Petrol, Gas, Ethanol)
    Last Post: August 7th, 2008, 04:30 PM
  3. help changing tire size!!!!
    By 2007silverado in forum General (Petrol, Gas, Ethanol)
    Last Post: June 2nd, 2008, 05:21 AM
  4. Adjust for tire size
    By Boost in forum General (Diesel)
    Last Post: March 29th, 2007, 10:32 PM
  5. Tire size change calulation
    By Z16DNA in forum General (Petrol, Gas, Ethanol)
    Last Post: January 19th, 2005, 07:52 AM
