Im looking into efi live and unsure what I need. Im putting a 04 gto ls1 into a rx7 and will need to be able to turn vats off and use as a tuning tool. Will be running a t-56 so will have no trans module and no bcm.
Hi Sleeping, welcome to the forum
For a 2004 GTO PCM you have two options:
- FlashScan V2
- FlashScan V1
[ For a 2005/2006 GTO ECM you have only one option, FlashScan V2. ]
V2 and V1 both do black box logging.
For the price difference, V2 gives you:
- serial comms interface to most widebands (i.e. digital AFR avoids analog voltage AFR offset problems),
- black box flashing (from SD card),
- advanced black box logging (multiple pid lists, alarms, LCD display, saving logs/cals to SD card, DTC scanning, Mode $6 diagnostics),
- newer vehicle ability (CAN/GMLAN) [just in case you get another powertrain/ECM/TCM].
What about the road runner feature?
The RoadRunner replacement PCM emulator is available from Moates and their selected resellers. As well as the physical RoadRunner PCM you also need to purchase the EFILive Realtime License which is US$199.
Andrew
EFILive Crew
