Results 1 to 5 of 5
Thread: Retrieving Black Box Data
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    Default Retrieving Black Box Data
    After logging several files to the FlashScan interface, I cannot retreive the data without being connected to the vehicle. When I start Scan Tool the FlasnScan menus are not active unless I am connected to the vehicle.
    The logging works great and I can retrieve the data as long as I am connected to the vehicle. Am I doing something wrong or is this the way it is intended to work (does not make sense to log without a laptop and then have to drag out the laptop to get the data).
    You should be able to click on "Connect" with just the FlashScn interface connected to your PC (with no vehicle attached).
    Once you are connected to the FlashScan cable the appropriate black-box logging menu options and toolbar icons should be enabled.
    Sep 2003
    That was too easy. I never thought to 'connect' when not attached to the vehicle.
    Thanks for your quick reply.
    Sep 2004
    I learned also. Planning to try Black Box Logging tonight. Thanks for the info....
    \'04 Z16 Corvette, AFR 205 heads, Comp 228/232 114+4 LSA custom cam, HS Rockers, Kooks 1 7/8\' headers, 3\" X-pipe, stock Ti tail section. \'98 Corvette Pace Car, \'04 Chevy Avalanche Z71 4X4.
    Lifetime Member 87gmc's Avatar
    Apr 2004
    Black Box is the best thing to happen to the scanning world
  1. SD on a black box OS?
    By Supercharged111 in forum Vortec V6/V8 Specific
    Last Post: April 12th, 2009, 04:50 AM
  2. MAF off on black box
    By pullincrazy88 in forum Gen IV V8 Specific
    Last Post: March 21st, 2009, 06:44 AM
  3. V2 Black Box data logging*vortec pid's*
    By GAMEOVER in forum Vortec V6/V8 Specific
    Last Post: October 7th, 2008, 05:01 AM
  4. Issue retrieving current emulated OS from roadrunner
    By ChrisB in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 2nd, 2006, 12:39 AM
  5. Black Box
    By TAQuickness in forum General (Petrol, Gas, Ethanol)
    Last Post: January 23rd, 2005, 04:33 PM
