Thread: Error $0502
    Jun 2008
    Default Error $0502
    I can get my files transfered to the Auto Cal fine, but when I plug into the car it says options missing on the display. All of the tunes are there but if I try to load one into the ecu I get a $0502?
    Any help would be great!!
    Oct 2004
    Given that error code and the fact is says missing Options it is simply a case of the AutoCal device having not been configured. You need to contact the tuner or workshop who provided you with the AutoCal for resolution.
    Andrew
    EFILive Crew
    Jan 2011
    I'm having the exact same problem. But I am now 2 states away from my tuning shop. Will I need to send my
    AutoCal device back to them to get it configured or will I be able to have it done by just sending files on my laptop?
    I was able to install the tune in my car by using EFILive Scan and Tune Version8 on my laptop, plugging my laptop into the AutoCal,
    while also having the AutoCal plugged into the OBDII port on car. But don't want to have to always carry around my laptop
    with me to change tunes.
    Oct 2004
    Your tuner "should" be able o resolve the issue for you without sending back the AutoCal device. They will simple just need to provide the correct preconfigured device settings, and then have you implement them locally with the V8 software you've already used.
    Andrew
    EFILive Crew
    Dec 2016
    Quote Originally Posted by Webbs View Post
    I can get a fat burner like this files transfered to the Auto Cal fine, but when I plug into the car it says options missing on the display. All of the tunes are there but if I try to load one into the ecu I get a $0502?
    I just got this 0502 error too. trying to fix it now.
    Jan 2009
    Follow the steps under the heading
    BBR & BBF (Black Box Reading and Flashing) Configuration
    https://support.efilive.com/kb_artic...6659-YAHB-3781
  1. Error 08 on my LM-1
    By Slowrc in forum General (Petrol, Gas, Ethanol)
    Last Post: April 20th, 2010, 03:43 AM
  2. ERROR. Please help
    By ntrimm in forum FlashScan V2
    Last Post: March 29th, 2009, 02:22 PM
  3. Error
    By ASSAMI in forum General (Petrol, Gas, Ethanol)
    Last Post: February 4th, 2007, 08:27 AM
  4. Com Error
    By Neilb in forum EFILive V4
    Last Post: January 6th, 2006, 05:57 PM
