Results 1 to 2 of 2
Thread: Setting rear O2 sensors to act as bank 1 (primary) O2 sensors
    Nov 2010
    Default Setting rear O2 sensors to act as bank 1 (primary) O2 sensors
    Hello all,
    I am building an LS1-powered car, and the longtubes on the car have the O2 bungs in the collectors. As such, I will either need to extend the primary O2 wiring harnesses, or (hopefully) use the rear O2 sensor wires as the primaries.
    Can this be done? I searched a bit and found a thread suggesting to simply turn off the MIL for the rear O2's, but this doesn't seem like a complete fix. Is this the popular way of having the rear O2 sensor wiring acting as the front O2 sensor wiring?
    Thanks, and sorry if this has been covered. I did search, but found a lot of "how to turn off rear O2" threads, not much pertaining to my question.
    Nov 2006
    Swap the front O2 wires with the rear ones at the PCM connector.
    LC-1 WBO2
  1. Rear O2 sensors for e38 VE V8 or G8?
    By hymey in forum General (Petrol, Gas, Ethanol)
    Last Post: October 18th, 2010, 10:32 PM
  2. Replies: 3
    Last Post: June 16th, 2010, 10:40 AM
  3. O2 Sensors
    By Elliott in forum Gen IV V8 Specific
    Last Post: August 20th, 2009, 12:39 AM
  4. rear 02 sensors
    By aaronr in forum Gen III V8 Specific
    Last Post: December 17th, 2007, 01:38 PM
  5. Disable rear o2 sensors?
    By Dlong in forum Gen III V8 Specific
    Last Post: January 6th, 2007, 11:16 AM
