Results 1 to 9 of 9
Thread: Looking for I6 LL8 E67 tune - anyone?
    Member tunedportcj5's Avatar
    Sep 2006
    Default Looking for I6 LL8 E67 tune - anyone?
    Forgive me if I have missed any obvious threads but I have searched plenty!
    I am looking for a LL8 E67 tune, list of comptable operating systems, and which OS's are compatable with which controller. I have the OS reference list, just need the know with OS's run the LL8 E67.
    Thanks!
    David
    drsmith99 at gmail dot com
    '94 Lexus SC300 LY2 4.8, LS6 cam/springs, E38, LS3 MAF, LS2 intake, 88mm TB, 2bar MAP, T42/4L80e, mpt70
    www.terratraction.com/gallery
    David, I thought I had one on my laptop but I dont...Ill check my external HD and get back to ya. FYI, I havent heard of any issues flashing an 09 LL8 E67 OS into an 07-08 E67 like the other OSs.
    Lifetime Member schwoch1's Avatar
    Jan 2009
    You ever get that E67 LL8 tune. I have one here if you need it from an '08 Trailblazer.
    Mike
    Current toys are as follows:
    1961 Chevrolet Corvair Monza, 145 H6/powerglide. 85 HP of raw fury.... slow and stock and staying that way!
    1969 GMC 2500, 4-53T Detroit diesel/Fuller 10 speed on late model 1500 HD frame
    1970 GMC 9500, 6-71 Detroit/Fuller 13 speed, not sure why I bought it, but it sure is noisy!!!
    1975 Ford F100 shortbed. Currently undergoing Crown Vic subframe swap and EFI 4.6!!!
    1975 Chevrolet Vega, 5.3/200-4R may finish someday, maybe...
    Post it up Mike! I thought I had one, but I might have not actually saved it to my laptop though.
    Jan 2009
    I just got one. Had to buy an E67 and have it flashed to it. I plan on multiporting my '62 Corvair using the LL8 cal. The electronic throttle should be nice, 15 feet of linkage to the rear of the car can get a little cumbersome!!! Those old flat 6 Corvair engines suffered from horrible mixture distribution, and EFI smooths them right out and makes them 100% more driveable than the original single carb per bank! I will keep all posted in anyone i interested!!
    Mar 2007
    Quote Originally Posted by schwoch1 View Post
    Not sure if anyone else had replied to this or not, but I am interested in the Corvair upgrade to an E67. My dad has a '64 and I have tried to talk him into doing something simple like using EFI from a TBI 2.8L V6 swap (close enough in size for starting purposes).
    Jan 2009
    Quote Originally Posted by turbo_bu View Post
    I have a feeling this is not going to be a 'simple' swap in many ways, but way doable. The biggest hurdle I have is getting the bungs welded into the head for the fuel injectors. Seems as if everyone in my town is afraid to weld aluminum. I could run two single point TBI setups like a couple of other Corvair guys have done, but that is only 1 step up from the carbs in my opinion. I am a HUGE proponent of EFI and anything less than multiport with the latest and greatest stuff and people would think that I am wimping out on them !!! I will prolly open a new thread when it becomes more interesting as not to hijack this one!!!
    I will keep posted!!!
    Mike
    Dec 2007
    Have some first hand experience now that E67's do suffer from "brickification" when mix and matching OS's. Like E38's, in some cases they dont go to brick (i.e. serial disappears) until a run/start cycle. The example was from a GM TIS flash (not a result of bypassing EFILive's new protection feature.) The 07-08 can be cross flashed, but they suffer the same VIN corruption as an E38 which tends to point toward the same munching of the NVRAM.
    Yup, I have firsthand experience with the VIN messup going from an 07->08 OS. Just had to change the VIN manually, havent had any issues other than wondering why EFILive wouldnt scan enhanced PIDs because the VIN was corrupt! Doh!
    Id stick to whatever year ECM to you have, the I6 only came with the E67 in 08 and 09 so I imagine GM didnt change much as 09 was a half-year run of TrailBlazer/Envoys but GM's been known to do weird things!
  1. Controlling Toyota's 2JZ with a LL8/E67 harness/ecm?
    By tunedportcj5 in forum Conversions / Aftermarket Parts
    Last Post: September 18th, 2011, 04:08 PM
  2. help with E67 tune pontiac solstice with turbo kit
    By billion01 in forum E37, E38 & E67 PFI ECM's
    Last Post: July 2nd, 2011, 10:52 AM
  3. what tune can i use for a 6.2L VVT W/E67 ECM
    By nycblazer in forum E37, E38 & E67 PFI ECM's
    Last Post: January 16th, 2009, 01:03 PM
  4. Looking for E67 .tun files for 2.4L LE5 and 4.2L LL8
    By 350SS in forum E37, E38 & E67 PFI ECM's
    Last Post: November 12th, 2008, 08:16 PM
  5. LL8 I6 VE tuning
    By blandmiller in forum General (Petrol, Gas, Ethanol)
    Last Post: October 9th, 2006, 10:19 AM
