Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: RePost
  1. #21
    Jan 2005
    Anyone having fuel issues, please check the value of {B3601} "Air Fuel Ratio for Stoich". It should be 14.63
    Some old *.cal files had an incorrect max limit of 1.0 which forced it to down to 1.0
    If that has happened the PCM will attempt to command 1:1 AFR (way too rich) when it should be shooting for 14.63.
    If that valus has changed, please change it back.
    Unrelated, the {B0106} "Crank:Run Blend Ratio" may also get incorrectly altered to 1. It's stock value is 8.
    Both of these two limits have been corrected in the latest *.cal files. But the *.tun file you are using may have been altered previously using a faulty version of the *.cal files.
    This was my problem, my {B3601} was set at 1, I had a excessive rich no start. If this happens to any of you, after you correct the problem, you have to hold the throttle wide open to clean it out to get it started. Otherwise, it won't start and you may think you still have a problem. (Unless the motor has sat for a while)
    Question: my {3604} and {B3605} tables and maybe others are in Lambda, I use AFRs in my LM1 wide band, is this a problem? How do you change these tables to AFRs.
    Thanks, Curt
    99C5, mn6, Vortec T trim, Snow meth injection, AFR 205s, ARP studs,Comp 224*112*+2*.580", YellaTerra RRs, PRC Ti's w/dbls, Supermaxx LTs, No Cats, Corsa Indys, LS6Intk, Hurst, Fikse Aro18"s. Pilot Sports 315/30,265/35, 04ZO6 Shocks Hotchkis bars, EBC YellowStuff pads, SS hoses, LM-1, EFILive, 2002 OS. RPS dual disc Clutch, DTE Strut Brace & output shaft.
  2. #22
    Jan 2004
    Open FlashScan.
    Edit - Properties (Alt+Enter)
    Under Display you have the option in the middle section to switch between AFR, Lambda, and EQ
  3. #23
    Jan 2005
    Quote Originally Posted by Black02SS
    Open FlashScan.
    Got it Chad.
    Thanks, Curt
  4. #24
    Jan 2004
    Not a problem.
  5. #25
    Open FlashScan.
    I hate figuring out lamda readings. AFR is so much easier to absorb!
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
  6. #26
    Make sure you read the section in the latest Scan Tool manual about how delta fuel tables may not always be accurately displayed by EFILive as AFR.
    Appendix-B, page 79.
    (Thanks to BlackO2SS for asking the right questions and prompting me to write appendix-B).
