Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: Strange AFR from Serial ZT-2 -- OFF by Factor of 10!
    Oct 2009
    Question Strange AFR from Serial ZT-2 -- OFF by Factor of 10!
    I recently changed from an Innovate LC1 to a Zeitronix ZT-2 serial wideband controller. Since the change I've noticed some strange AFR's when the ZT-2 is plugged in using the serial cable to the flashscan V2. AFR readings seem to be off by a factor of 10. For example when the actual AFR is 14.5 the flashscan will show 1.45 during BBL. I think I have everything configured correctly, but I've got to be missing something simple. I have the following settings:
    Com Port: Wideband
    Wideband: Zt-2
    Format: 1st wide band only
    Data Display: AFR only
    Do I need to create a calc PID or log a different pid for the ZT-2. I'm currently using EXT.WO2AFR1 same as I did for the LC1.
    Hi mirage,
    I pm'd Tech Support, they may ask for more info.
    Oct 2009
    Do the custom PID properties in V8 work with BBL? It looks like I should be able to adjust the output by a factor of 10, but changing these values doesn't seem to affect BBL or the logs. I know this would be a work around if it worked...
    Oh and thanks Joecar we the users of the forum appreciate the help!
    Oct 2004
    I've emailed Paul already based on your email to us. I'm sure it will be something simple
    Andrew
    EFILive Crew
    Thanks for uncovering that bug. It was a fault in the FlashScan firmware. It will be fixed in the next update.
    Oct 2009
    So does that mean it was truly off by a factor of 10? If so I can make a calc pid that simply multiplies the EXT.WO2AFR1 by 10 to get me by until the next release of the firmware?
    Oct 2004
    I would say it is going to be a presentation but, with the PID scaling simply being incorrect. You'be should be safe to create a CALC PID if you wanted. We are hoping to have a new firmware out pretty soon to correct a number of outstanding issues if you're not desperate.
    Andrew
    EFILive Crew
    Nov 2006
    Does it have the option of Lambda/EQ?
    Lambda*stoich AFR=AFR
    stoich AFR/EQ=AFR
    You may even need to use analog until the next update.
    LC-1 WBO2
    Oct 2009
    Quote Originally Posted by mr.prick View Post
    stoich AFR/EQ=AFR
    Looks like it I'll try it tomorrow, but good to know the firmware update is coming soon. Thanks guys.. I appreciate the help!
    Sep 2007
    Did this ever get worked out?
    Mirage can you show me how you connected the Zt2 to the flashscan?
  1. PLX SM-AFR Serial upgrade
    By ntae in forum FlashScan V2 BB Logging
    Last Post: May 25th, 2017, 08:26 AM
  2. Serial AFR Reads 25.00
    By AGRO in forum FlashScan V2 BB Logging
    Last Post: April 30th, 2010, 03:30 AM
  3. Serial Wideband AFR & B3601
    By WeathermanShawn in forum General (Petrol, Gas, Ethanol)
    Last Post: April 25th, 2010, 05:51 AM
  4. Converting serial Lambda to AFR
    By mr.prick in forum FlashScan V2
    Last Post: December 31st, 2009, 03:06 PM
  5. plx sm-afr serial
    By blazinblue in forum General
    Last Post: June 23rd, 2009, 08:29 AM
Tags for this Thread
