Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 53
Thread: Strange AFR from Serial ZT-2 -- OFF by Factor of 10!
  1. #21
    Nov 2006
    From the picture it looks like there are 2 null modems connected to a gender-bender.
    Try using one null modem and the V2's serial cable to the DB9-RJ12 adapter.
    BTW your V2 appears to be faded or are the blue now?
    LC-1 WBO2
  2. #22
    Sep 2007
    For some reason my V2 did not come with the DB9 Serial cable????? I thought it was suppose to?
    As far as I am aware the Zt2 does not provid e fuel pressure signal, unless you are using the USER defined values in the Zt2-s data stream.
    If that is the case FlashScan does not currently log the USER defined values.
    Yeah the fuel pressure is a USER input into the Zt2. So yes its in the USER defined value of the data stream. Oh well, maybe someday.
    You need a null modem adapter not a gender bender.
    This thread explains why two DCE devices (or two DTE devices) cannot be directly connected without a null modem adapter:
    http://forum.efilive.com/showthread....hat-goes-to-v2
    PC = DTE device
    V2 = DCE device
    WB = DCE device
    So, the following connections work:
    - PC -> V2
    - PC -> WB
    - V2 -> null modem adapter -> WB
    A null modem adapter says "null modem" on it.
    Your cable looks over-engineered... look at post #3 in that thread... or cut up your cables and solder them together with the Tx/Rx pins swapped.
    The black piece is a female-female null modem connector, the other two are just gender benders. I think I need to get the smaller null modem in that other post, which is a male-male connector
  3. #23
    Nov 2006
    Quote Originally Posted by NoJuice View Post
    If bought new, it should have. -> Spare Parts
    Looks like I had it backwards.
    With the pinout above can you just plug the zt-2 cable into the V2?
    LC-1 WBO2
  4. #24
    Sep 2007
    Yeah I need the third cable down on the "Spare Parts" page.
    The Zt2 cable physically plugs into the V2 but in order for it to work you need to swap the two pins, hence the need for the null modem connector and the serial cable shown above.
  5. #25
    The serial cable was removed from the parts list for FlashScan about 6-9 months ago.
    It was been re-introduced as standard about 1 month ago.
    In the US you can purchase spare serial cables for EFILive's distributors, listed here:
    http://www.efilive.com/index.php?opt...=60&Itemid=153
  6. #26
    Sep 2007
    Hmmm.....thats odd, got this a couple weeks ago. Maybe my box got missed then.
  7. #27
    Send me (paul@efilive.com) your shipping address and I'll send you a serial cable.
  8. #28
    Sep 2007
    Email sent
  9. #29
    It was re-introduced as standard about 1 month ago.
    Correction. The serial cables are being added back into the product in the September 2011 shipments from EFILive. So the boxed product with serial cables will start to filter out to Resellers/Customers after that.
    Sorry for any confusion. I should have checked my facts before posting...
  10. #30
    Lifetime Member Chalky's Avatar
    Sep 2003
    For JoeCar
    2015 Z06 A8
  1. PLX SM-AFR Serial upgrade
    By ntae in forum FlashScan V2 BB Logging
    Last Post: May 25th, 2017, 08:26 AM
  2. Serial AFR Reads 25.00
    By AGRO in forum FlashScan V2 BB Logging
    Last Post: April 30th, 2010, 03:30 AM
  3. Serial Wideband AFR & B3601
    By WeathermanShawn in forum General (Petrol, Gas, Ethanol)
    Last Post: April 25th, 2010, 05:51 AM
  4. Converting serial Lambda to AFR
    By mr.prick in forum FlashScan V2
    Last Post: December 31st, 2009, 03:06 PM
  5. plx sm-afr serial
    By blazinblue in forum General
    Last Post: June 23rd, 2009, 08:29 AM
Tags for this Thread
