Results 1 to 2 of 2
Thread: Delphi 2Bar map sensor settings Part Number 16235939
    Mar 2005
    Default Delphi 2Bar map sensor settings Part Number 16235939
    After trying to find correct offset info and scalar info for this map sensor I ended up doing it myself using the dyno map sensor and arrived at these numbers.....
    Scalar:202 (defines the "spread" of total measurement)
    Offset:7 (simply moves the entire calibration in KPA up or down by this number)
    Checked "key-on" equals 101kpa and at idle logged EFILIVE MAP equals Dyno MAP reading.
    E38 computor in a VE Holden L98 engine.
    Keywords: offset scalar map delphi 16235939 efilive LS3 LS2 LS1 L98 boost supercharger turbocharger
    I hope this helps people
    Please check and verify against a known map measurement device before tuning.
    Mike
    "Just a tune > yeah right !!!! "
    May 2008
    Thanks for posting this info, a lot of people should find it useful.
    E85 is NOT flex fuel.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
  1. Anyone useing the 3.3 Bar Delphi Map sensor ?
    By johnv in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 9th, 2013, 11:00 AM
  2. Injector part number
    By GMPX in forum Gen III V8 Specific
    Last Post: June 23rd, 2009, 12:32 AM
  3. 06 LBZ PCM Part Number
    By SSTuner in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 17th, 2007, 10:42 PM
  4. Map Sensor Part#'s
    By ForcedC5 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 13th, 2006, 08:59 PM
  5. 2Bar MAP Sensor with MAF Question
    By vetteboy2k in forum General (Petrol, Gas, Ethanol)
    Last Post: October 9th, 2005, 08:26 AM
