Attached is COS5/02020005 file that I run on my stock 2001 TA (everything stock other than long tube headers w/cats).
wheres the AFR vs map/rpm? i cant seem to see that ...
thanks man!
Service number 12582605 was a commonly used 1Mb LS1-B style PCM in 2003 Gen III trucks. I believe it will only support DBW tunes.
Some service numbers for 2003 LS1-B PCMs that should support DBC tunes are:
- 12576106
- 12581565
- and no doubt - a few more less “common” service numbers
Any 2003 to 2007 Gen III PCM will work with the BLUE & GREEN PCM connectors of your wiring harness. There are select PCMs from 2003 to 2007 that are DBC compatible.
You could also use any 1999 to 2002 512Kb LS1-B PCM - these are all DBC compatible - but you would have to switch the GREEN PCM connector to a RED PCM connector - and repin the wiring harness as necessary.
Regards,
Taz
