Results 1 to 10 of 13
Thread: Help VIN disappeared during tune!
    Nov 2010
    Default Help VIN disappeared during tune!
    Help! Was tuning the car and now my vin has disappeared is telling me i have to register the vin and is now showing a vin of N/A0000000000000 in the PCM any assistance would be greatly appreciated. Did the PCM just die? car still runs.
    Which vehicle/year/model...?
    FlashScan V1 or V2...?
    Which V7/V8 software build versions...?
    Which V2 bootblock/firmware...?
    Do not proceed until Tech Support gets back to you.
    Nov 2010
    PCM is from an 02 Suburban was reflashed as an 02 camaro and is in my 71 Nova flashScan v2 v7.5
    You can program the VIN back into it using the V7.5 Scan Tool software, menu option Bidirectional->Change VIN...
    Can you locate the most recent *.blx files as per this: http://support.efilive.com/kb_articl...8254-QOGC-9586 (under the heading "Further Support").
    And then send them to me at paul@efilive.com
    Quote Originally Posted by tidony View Post
    You may have to update the V2 firmware to stop this from happening again (which means you have to update the V7 and V8 software).
    Nov 2010
    Still telling me that my ecm is not licensed to my cable after reprogramming the VIN
    Does your ECM have a valid serial number now? You can check using the Tune Tool menu option: Flash->Show PCM info, then select the correct controller type and click on [Get Info].
    Post the serial number that is displayed. If it is valid then we can send you a replacement license for your V2 device to re-license your controller.
    Lifetime Member Biggsy's Avatar
    Jan 2007
    The cable uses the ECM's serial number to licence it, not the VIN.
    Dave.
    Nov 2010
    Here is the serial number EF10AFB81217
    Nov 2010
    [QUOTE=Biggsy;133477]The cable uses the ECM's serial number to licence it, not the VIN.[/QUOTE
    I am aware of this however while tuning the vehicle last week the VIN dissapeared from the ecm along with the licensing for serial number
  1. Can anyone get my a stock tune from a VIN
    Last Post: February 21st, 2010, 09:09 AM
  2. lmm high idle disappeared
    By rubbersidedown in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 24th, 2010, 09:28 AM
  3. EFI Live Disappeared
    By petestoy in forum Purchase and Shipping
    Last Post: January 13th, 2008, 04:05 PM
  4. Copying tune to different VIN
    By kbbrett in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 23rd, 2007, 06:55 AM
  5. Vin # in tune does not show the same as my vin...
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: February 11th, 2007, 10:04 AM
