Results 11 to 20 of 26
Thread: November 22nd 2010 pre-release
  1. #11
    Apr 2008
    Quote Originally Posted by L31Sleeper View Post
    So basically you are saying that Odd Boy shot himself in the foot !! by increasing the number?
    no brother, even if I request new number it uses the number that is originally assigned by efilive team after completing the update!!!! Beautiful, isn't it???
    Regards,
    Odd Boy
  2. #12
    No not really, what he did will work and obviously did work, quite clever really.
    It is just a bit quicker/simpler to use EFLive_Explorer in this particular case.
  3. #13
    Nov 2009
    2006 Commodore
    08:29:39.716: Scanning for EFILive FlashScan V2 HAPI
    08:29:39.747: Autodetect interface ...
    08:29:40.028: Interface firmware version: 2.7.3
    08:29:40.043: Connection to [FSV2] interface is OK
    08:29:40.293: Interface firmware model: FSV2
    08:29:40.324: Interface firmware version: 2.7.3
    08:29:40.355: Interface firmware date: Nov 18, 2010
    08:29:40.386: FlashScan serial number: 003782291113
    08:29:40.418: FlashScan license number: 003782291113
    08:29:40.464: Disconnecting ...
    08:29:41.088: CAN-VPW Bridge Deactivated
    08:29:41.104: Disconnected
    08:29:41.806: Scanning for EFILive FlashScan V2 HAPI
    08:29:41.837: Autodetect interface ...
    08:29:42.134: Interface firmware version: 2.7.3
    08:29:42.165: Connection to [FSV2] interface is OK
    08:29:42.212: CAN-VPW Bridge Activated
    08:29:42.290: Current protocol set to: "SAE J1850 VPW"
    08:29:42.321: Autodetect PCM...
    08:29:42.586: Connection to PCM is OK
    08:29:42.617: Autodetect TCM...
  4. #14
    Um, Suhail what are you trying to show here? You need to manually update your firmware still, you have the November 18th version loaded now not the November 22nd.
  5. #15
    Oct 2004
    He saw me do that when I was trying to downgrade his firmware originally to 2.07.01 . I didn't think it worked in Hapi though as the internal version is still the same. Might try that later myself...
    Andrew
    EFILive Crew
  6. #16
    Quote Originally Posted by Tordne View Post
    It won't work for downgrading...
  7. #17
    Apr 2008
    Touch the wood, u still remember.....
    You offered me a good help on that day, I am a good student "never forget" from the first seen.........
    Thanks again
    Quote Originally Posted by Suhail View Post
    2006 Commodore
    Suhail,
    Call me this afternoon to upgrade the firmware if you still have the issue
    Regards,
    Odd Boy
  8. #18
    Senior Member Wasted Income's Avatar
    Dec 2005
    Pass-thru reading would NOT work on an LBZ that I attempted to read this afternoon. However, it worked fine on my LS1.
    2005 Silverado Duramax LLY - EFI Live Tuned
    1969 Chevrolet C-10 Pickup - Turbocharged 5.3L/4L80E - EFI Live Tuned
    1975 Avenger Jet Boat - 6.0L/Berkley pump - EFI Live tune in progress
  9. #19
    Dec 2005
    Is it because I was trying to use 7.5 to read the ECM? Do I need to use V8 or scan and tune or what? Need to make a few tweaks to a buddys LBZ that I previously tuned and I am not currently able to. Thanks.
  10. #20
    Apr 2008
    did apply the latest firmware update?
    Regards,
    Odd Boy
  1. November 18th 2010 pre-release
    Last Post: December 2nd, 2010, 05:04 PM
  2. August 12, 2010 Pre-release
    Last Post: September 29th, 2010, 07:12 AM
  3. Pre release 7.5.1
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: October 4th, 2007, 08:55 PM
  4. V7.1.9 Pre-release is now available
    By Blacky in forum General (Petrol, Gas, Ethanol)
    Last Post: April 13th, 2005, 02:47 PM
