how would i go bout settin up my flash scan for temp gauges
What year/model/vehicle...?
What temps (coolant, transmission)...?
Software scantool:
On the Dashboard, goto Dash A, and do rightclick->Add and select a gauge, or do rightclick>Properties on an existing gauge and change its pid.
V2 BBL:
Run the V8 Scan&Tune software, select Black Box Settings, create a pid list for your PCM/ECM/TCM including temp.
BTW: welcome to the forum.
In that case you need this:
See here, starting from post #5: showthread.php?14351-BBL-PIDs-V2
03 2500 hd 6.6 for temporary gauges like speed trans temp coolant my cluster is messed up i wanna just use the v2 and not have to have the lap top in the truck the battery on the lap top might last 15 min
now where is the scan and tune or how do you get thier the only thing i can find is the scan and tune tools
You also have to install V8 software from >here<
[ also, you should probably update your V7 software ]
V8 software gives you two software tools: EFILive Explorer and Scan&Tune.
More info:
showthread.php?13836-New-V2-help-find-exlporer post #4
its telling me to terminate the hapi process how do i do that
ok ive got to programing the v2 and it says error $0003: usb device noy opened what to do now thanks for the help
I contacted Tech Support about Error $0003.
Which V8 software build version have you got installed...?
