how would i go bout settin up my flash scan for temp gauges
What year/model/vehicle...?
What temps (coolant, transmission)...?
Software scantool:
On the Dashboard, goto Dash A, and do rightclick->Add and select a gauge, or do rightclick>Properties on an existing gauge and change its pid.
V2 BBL:
Run the V8 Scan&Tune software, select Black Box Settings, create a pid list for your PCM/ECM/TCM including temp.
03 2500 hd 6.6 for temporary gauges like speed trans temp coolant my cluster is messed up i wanna just use the v2 and not have to have the lap top in the truck the battery on the lap top might last 15 min
BTW: welcome to the forum.
In that case you need this:
See here, starting from post #5: showthread.php?14351-BBL-PIDs-V2
now where is the scan and tune or how do you get thier the only thing i can find is the scan and tune tools
You also have to install V8 software from >here<
[ also, you should probably update your V7 software ]
V8 software gives you two software tools: EFILive Explorer and Scan&Tune.
More info:
showthread.php?13836-New-V2-help-find-exlporer post #4
its telling me to terminate the hapi process how do i do that
ok ive got to programing the v2 and it says error $0003: usb device noy opened what to do now thanks for the help
I contacted Tech Support about Error $0003.
Which V8 software build version have you got installed...?
