Results 1 to 7 of 7
Thread: Error: $0537
    Nov 2010
    Default Error: $0537
    trying to read tune off 99+ LS1 PCM and get an error $0537. Can anyone help? new to all this.
    (yes I have latest software. I've reinstalled it too.)
    $0537 Controller is locked with a custom key. An attempt was made to read or program a controller that cannot be unlocked using the standard GM keys. If you know the key that was used to lock the controller, please use the unlock option in the EFILive software to unlock the controller before attempting to read or re-flash the controller again.
    Has the controller been tuned before? If so you'll need to contact whoever tuned it to get them to unlock it.
    Sometimes GM's programming system can mess up the lock on the PCM. If the controller has been reprogrammed by a dealer you may be able to unlock it using the key $FFFF in the V7.5 software.
    Nov 2010
    Thanks for that. Yeah it has already been tuned. Bugger.
    Can you ask the programmer what key they used?
    Mar 2014
    I have the same problem I have the programmer they used but am not sure what the key is. Do I still need the key if I have the original programmer that turned my truck???
    Nov 2011
    You are going to need the key to get in. You will have to hope the programmer is willing to give the key out. Given that they locked it I don't like your chances.
    Mar 2014
    So if I can't get the key what are my choices
  1. Error 08 on my LM-1
    By Slowrc in forum General (Petrol, Gas, Ethanol)
    Last Post: April 20th, 2010, 04:43 AM
  2. ERROR. Please help
    By ntrimm in forum FlashScan V2
    Last Post: March 29th, 2009, 03:22 PM
  3. Error
    By ASSAMI in forum General (Petrol, Gas, Ethanol)
    Last Post: February 4th, 2007, 09:27 AM
  4. Com Error
    By Neilb in forum EFILive V4
    Last Post: January 6th, 2006, 06:57 PM
