Results 1 to 10 of 13
Thread: should I buy ?
    Nov 2010
    Default should I buy ?
    I have recently bought a VE SS MY10 6L 6man . It is going in for exhaust - OTRCAI - dyno tune with efi live.
    I am considering buying V2 and running it with a small 10inch netbook all the time. ?
    I won't be doing any tuning initially but want the ability to as i learn more about the subject, but till then still want to log data so I can go back to my tuner every so often for updates.
    Guess what I'm asking is it worth the money as a tool ? I have bought as expensive tools for other things so it's not overly expensive to me. I'm in Aus so OZTrack is my local , and I can get for around $900 or $1100 with initial set up support. Plus $400 for netbook.
    Nov 2006
    I suggest it.
    LC-1 WBO2
    Nov 2010
    I should also mention that I am running dual Aeroforce Interceptor gauges that plug into the CAN port. Can i still run V2 efilive at the same time ,
    Oct 2004
    I wouldn't imagine you run two scan tools on the CAN bus at the same time. Are the existing gauges displaying anything that your couldn't get in EFILive?
    Andrew
    EFILive Crew
    Nov 2010
    the gauges scan through various parameters but only have a record function of around 1min 15 sec for 1/4 mile runs .
    Nov 2007
    I don't know what OTRCAI is ?? but I don't really think you have enough mods to NEED a v2.
    I mean I think it's a good idea for every body !! I looked at those gauges and I really like them
    but the web site doesn't say if their OBD2 plug is a Pass Through or not. Maybe call them.
    Aug 2008
    Quote Originally Posted by L31Sleeper View Post
    OTRCAI=Over The Radiator Cold Air Intake
Name:	L76 intake.jpg
    FLASHSCAN V2 & AUTOCAL
    Quote Originally Posted by conrodss View Post
    You may not need V2... but it sure a fun tool to have (if you don't mind spending the money)...
    it takes an SD card, so it can record any trip you make (yep, even across Oz the long way).
    [ don't let me influence you, I'm extremely biased ]
    Nov 2010
    are you an aussie living o/s ? this is the reason of getting it so I can log data then take it to my tuner and go over it and make corrections , this is how I will learn to use it to its full advantage , going to dedicate a couple (few) of weekends to reading this forum (or more the way I am) to get me strated logging data , not going to attempt any changes until I AM FULLY CONFIDENT .
    a bit of cart before the horse and picked up a nice 10.1 netbook that will sit nicely in the car.
    Yes, I'm a Sydneysider living in Southern California at the moment... ]
    To try out the software, you can download/install it from here: V7.5 software
    More info on tuning, follow the links in my signature below:
  1. What to buy?
    By Sleeping in forum Purchase and Shipping
    Last Post: November 1st, 2010, 07:00 AM
  2. i want to buy,but what should i get and for how much?
    By sand man in forum Purchase and Shipping
    Last Post: December 9th, 2009, 04:37 PM
  3. Where to Buy???
    By Tirefire in forum Purchase and Shipping
    Last Post: October 27th, 2009, 04:00 PM
  4. What to buy...
    By Macon@MMP in forum FlashScan V2
    Last Post: December 28th, 2006, 05:24 AM
  5. What do I need to buy
    By boxhead in forum General (Petrol, Gas, Ethanol)
    Last Post: December 28th, 2004, 11:28 PM
