I am still chasing my tail with my dieseling. I have a tune that I would like to emulate. I'm stumped trying to get the B4001 from my source tune over to my stock tune base. I am using the stock tune from my car and I am updating the tables manually. My source B4001 IFB is VAC PSI vs IFB (Lbs/Hour) My stock B4001 is Delta MAP PSI vs IFB (Lbs/hour)
How do I change my stock B4001 to where it matches my source B4001 so when I copy and paste, the tables appear the same and the graph has the same "plots"?
Elmer
