Results 1 to 10 of 11
Thread: Vitural VE changing in all the wrong places
    Senior Member Naf's Avatar
    Aug 2006
    Default Vitural VE changing in all the wrong places
    Ok, i got my engine engine dynoed and they sent me the file, but in the car my idle is slightly lean, 15.5-17.2. I tried to just change the 400-1000 where the problem is, but when i look at my changes, it also makes changes all over the place. And i cannot reverse the other cells at all.
    How may i just richen my selected areas without messig with the rest of the map???
    American Muscle, European Design, Japanese Tactics
    Naf, can you post your file...?
    Aug 2006
    Sorry it took me a while, but my log was a little too long to post as it was...
    Everytime i try and fix the VE below 1000rpm in the areas that are lean it alters everywhere else.
    Thanx for your help, and if you would share your knowledge on how you do it in selected cells only, i would be extremely appreciative
    Aug 2008
    Thats what sucks about tuning the VVE, I couldn't get it to change where I wanted it to either....That's why I went MAF only....Easier & faster to tune with a wideband of course...
    FLASHSCAN V2 & AUTOCAL
    I'm not up on VVE, but someone here will know...
    Im tempted to tune my SS MAF only then dial the VVE in and see what driveability is.
    Aug 2006
    If i increase the MAF values what happens to the AFR?
    I cant remember, its been a while since i messed with one...
    May 2010
    if you increase the MAF the the car will go lean
    EFILive Tuner
    Sep 2010
    There is nothing wrong with tuning MAF only. You can pickup some throttle response and drive-ability by doing both VVE and MAF.
    Paul Meister
    EFI Calibrator/Managing Member, Torq Speedlab, LLC
    Specializing in late model Ford, GM and Dodge EFI Calibrations
    SCT, EFI Live, HP Tuners, FAST, BS3 and much much more
    Hi wesam,
    If you increase the MAF table, then then ECM will calculate an increased cylinder airmass, which in turn causes it to calculate an increased fuelmass, which causes wideband measured AFR to be richer (since the actual airmass is unchanged).
  1. BBL data display/record decimal places
    By Kevin Doe in forum FlashScan V2 BB Logging
    Last Post: March 27th, 2008, 03:46 PM
  2. HELP!!!! VE seems wrong, after using RR
    By vxleather in forum RoadRunner Real-Time PCM Emulator
    Last Post: March 26th, 2008, 08:30 AM
  3. Can anyone see anything wrong here???
    Last Post: February 4th, 2008, 09:29 AM
  4. What am I doing wrong?
    By wildwhl in forum Black Box Logging
    Last Post: July 7th, 2006, 12:55 PM
Tags for this Thread
