Results 1 to 2 of 2
Thread: setting to imperial?
    Oct 2010
    Default setting to imperial?
    Is there a way to set the whole tune tool to imperial so if im trying to figure out shift points and mph etc I don't have to run through a conversion?
    You will want to set both tunetool and scantool the same (so that scan->tune pid linking works right)...
    In scantool:
    - go Edit->Properties->Options->Preferred Unit System and click on Imperial, then click Ok.
    - goto PIDs tab, do CTRL-A (to select all), do rightclick->Imperial.
    In tunetool:
    - go Edit->Configure Display Units, click All (to select all), do rightclick->Imperial, click Ok, restart tunetool.
  1. Duramax Imperial selection
    By JustinD in forum Duramax LB7
    Last Post: September 1st, 2010, 03:29 PM
  2. Imperial pids for BBL?
    By thunderstruck507 in forum Black Box Logging
    Last Post: February 9th, 2010, 04:04 PM
  3. Imperial vs Metric
    By killerbee in forum General (Diesel)
    Last Post: September 3rd, 2009, 09:16 AM
  4. Changing Pids to Imperial??????
    By turboolds in forum FlashScan V2 BB Logging
    Last Post: June 17th, 2009, 10:17 AM
  5. Imperial MAP values seem backwards
    By kp in forum General
    Last Post: March 9th, 2005, 06:40 PM
