Results 1 to 6 of 6
Thread: How to log 3 axis?
    Oct 2010
    Default How to log 3 axis?
    Ok say if I want to create a map for main inj timing, can I log it using the axis of rpm, map and throttle position or does it only allow 2 axis?
    Only 2 axis on a map.
    Jul 2003
    Why would you need to do that? There are no 3 axis maps on efilive?
    A third axis could be "achieved" if you filter the data.
    Nov 2006
    Wouldn't the 3rd axis be the data logged?
    LC-1 WBO2
    The OP wants the 3 axis's to be RPM, MAP, TP and the data ti be injector timing.
    Jul 2005
    you can make multiple 'projections' of a 4D map onto a 3D graph. Basically you'd make a map of MAP,RPM vs INJTIMING, for all TPS<10%, then >10% and <20%, etc.... you end up with 10 maps for different throttle 'subsets'
  1. changing table axis
    By Gregs in forum General
    Last Post: September 9th, 2010, 01:37 PM
  2. Main Injection pulsewidth axis change
    By vortecfcar in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 21st, 2009, 01:17 PM
  3. Incorrect Axis In OL Fuel Tables
    By swingtan in forum E37, E38 & E67 PFI ECM's
    Last Post: May 17th, 2008, 10:23 AM
  4. Can the timing tables 'x' axis be changed
    By Jason S. in forum General (Petrol, Gas, Ethanol)
    Last Post: May 1st, 2007, 07:54 PM
