I noticed the site for the serial cables is down and his email is bouncing. Anyone know a way of contacting him for a lc-1 serial cable?
You could PM him.
LC-1 WBO2
Yeah definitely PM at the moment. I believe he is still waiting on his Internet connection at the new house...
Andrew
EFILive Crew
Is there any one else to get a v2 - lm2 serial cable i am based in the uk and can not get hold of TQ Cables,is it not possible to make one,does any 1 have a drawing
Hi Warren welcome to the forum
See post #5: showthread.php?8115-FlashScan-to-LC-1-Serial-Cable-Diagram
wow super fast,my unit is LM2 - V2 i think the plugs differ so still would not no which wires to put in which holes and what type of plugs to buy,i would be more than happy to purchase a serial lead if i could get it quick.
You could make your own.
This is the pin out for the LM2.
PHP Code:
V2 Serial LM2
1 <---> Tx Data <---> 2
2 <---> Rx Data <---> 1
5 <---> Ground <---> 3&4
LC-1 WBO2
Thanks for that ,As you probably gathered electrics not my field ,but how do i no which pins they are in both my V2 and LM2,any chance of a plug photo or something.
As a side note we are using standard LS7 motors with the GMPP hook up kit, E67 (i believe) ecu and fly by wire throttle any body had any experiance with this set up,any good straight out the box.
Then until TAQuickness comes back online, see the null-modem adapter (orange coloured adapter) shown in post #3 here:
showthread.php?9340-serial-port-cable-that-goes-to-v2
New to the forums and just got my V2. I have an AEM UEGO and was wondering the same thing about TAQuickness...havent been able to access his site for a while and Im in need of a serial cable to hook up to my V2. Anyone else running an AEM unit and have a serial cable? If so, where did you get it or am I better off just making my own. Tried to PM TAQuickness but dont have those privelages yet...I guess its most likely cause Im new to the forum. Thanks for any help.
Chris
'01 Camaro SS - 402CI, 11:1, Forged internals, Dart Heads, Comp Cam, LS6 Intake Mani, Ported Throttle Body, Pacesetter Long tubes, Pro 5.0 Shifter, 4.10 Gears
