Results 1 to 10 of 14
Thread: 2011 Camaro L99 Scan PIDS?
    Nov 2003
    Default 2011 Camaro L99 Scan PIDS?
    Just got my new 2011 Camaro L99. I wanted to check to see how close the stock tune is. What PID's do I need to scan? I assume I need ST-LT trims and MAF pids. My last car was Speed Density so it has been many years since I have had a stock car with NB O2's and a MAF. I do not have a WD installed yet.
    I feel like a newbie again.
    Bill
    2011 Camaro 2SS/RS L99 RJT
    VMax Ported RJT Throttle Body
    Gorilla Wheel Lock System;
    Apr 2008
    E38 PID shall be fine with you.
    Regards,
    Odd Boy
    Nov 2003
    I do not have a valid E38 PID. I need more than one PID don't I?
    Hi Bill,
    odd boy means the set of pids beginning with E38... i.e. E38.xxxxxx.
    On the PIDs tab, click on the column heading "Parameter" to sort on that column, scroll down you will see E38.xxxxx.
    Connect to E38 and validate PIDs first! I always forget to do that!
    Nov 2003
    So the E38 can only use E38 PIDs?
    Thanks.
    Bill
    The E38.xxxxx pids are exclusive to the E38 ECM...
    some of the other pids are also used by the E38 (e.g. VSS, ECT, IAT, MAF, LONGFT1/2, SHORTFT1/2, SPARK, KR, KNKRE, ...)
    Nov 2003
    My V2 hardware is not setup right. I did an upgrade and everything seems to work OK. I also did a firmware upgrade on the V2 and have the latest software installed. I cannot select any E38 pids. I ran validate PIDS and modules. I did download the two tunes using the 7.xx software on the notebook. I do a connect with PIDS selected other than E38 and it connects OK. When I do a record nothing happens. No activity on any of the PIDs. This must be operator error. What am I doing wrong guys?
    Thanks.
    Bill
    Bill, you press the red record button (not the yellow monitor button), right...?
    Nov 2003
    Right. I have been using EFILive since 2003 so I am not a newbie. I have always had V1 hardware.
    Bill
  1. 2011 Camaro L99 Stock Tunes
    By BowlingSS in forum E37, E38 & E67 PFI ECM's
    Last Post: December 16th, 2010, 04:14 PM
  2. Active Fuel Managment in a 2011 Camaro L99?
    Last Post: December 11th, 2010, 07:49 AM
  3. Reducing TM in a 2011 Camaro L99??
    Last Post: December 6th, 2010, 01:26 PM
  4. 2010 Camaro L99 vs a 2011 Camaro L99 Tune.
    Last Post: December 6th, 2010, 10:33 AM
  5. Tuning a Camaro 2011 A6 L99 questions.
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: November 5th, 2010, 12:33 PM
