Does anybody know what test can be done on an LSI to determine if the vats are active or not without a tuning tool to look at the program settings.
thanks in advance
Yortt
thanks in advance
Yortt
Log the State PID for VATS.
The setting in the PCM won't disable VATS completely in a lot of the LS1 vehicles anyways.
This is especially true with the Fbody as the BCM controls the starter relay.
LC-1 WBO2
Thanks for the response, I believe with the Australian Holden vats being serial when turned off it does completely disable the vats. Log the State PID for VATS is fine if you have a scan tool I was interested to know if you can check if the vats are active without a tune/scan tool.
