In dire need of assistance and help!!!
I tuned my buddies 2003 5.3l vortec chevy half ton. I put the AFR down to 12.9 (Natural Aspirated) and increase the throttle response. I was make a test run when the truck shut off, said REDUCED ENGINE POWER and coasted to a stop. I tried to restart it and it wouldn't. This time it said ENGINE OVERHEATED. This continued until the battery pretty much ran dead. I pulled it back to our house and let it sit, figuring it would cool off and everything would be fine. I come out this morning, hook up the jumper cables and turn the key. I get the REDUCED ENGINE POWER again, truck will not start or crank over...nothing. I hooked back up the EFI Live scanner and decided to reflash the truck back to stock, thinking that it would reset the codes. I hook it up, it starts unlocking the PCM, and then an error window pops up and says:
Bootloader rejected.
Reason:
One of the following conditions was set:
- Engine speed is not zero
- Vehicle speed is not zero
- A flash memory fault has been detected
(Only option was to select OK)
So by now I am very frustrated and am worried I made his truck a yard ornament by frying the ECM or something to that effect. I looked online, and found bits and pieces, but nothing that describe my situation. I found a couple of posts saying that resetting the ECM will clear the codes by disconnecting the battery and switching the headlights to the on position for 10 minutes to drain all power from the PCM. I tried that and no difference. Still REDUCED POWER and still rejects bootloader. I am in desperate need of assistance, so please respond as quickly as you can. Feel free to skip emailing and call me. Phone number is 937-302-0413.
Thanks!!!
Andrew
