Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Need help selecting and tuning for LS2 EV6 Shorty injectors for my LY7 V6 please!
    On either end of the 400-480kPa range, the IFR flattens out... this means either of these:
    - non-boosted application,
    - FPR has help during boost (i.e. manifold-referenced during boost, and non-referenced during non-boost).
    The range below 400kPa is boost.
    Sep 2010
    hwo do I find the data values below 400 KPA for the Delta Map?
    You can calculate them:
    IFR = R0 * sqrt(DeltaMAP / P0)
    where:
    R0 = flowrate when DeltaMAP is 400kPa = 5.2600 g/s (from your post)
    P0 = DeltaMAP when MAP is BARO = 400kPa
    i.e. IFR = 5.2600 * sqrt(DeltaMAP/400) where you set DeltaMAP to values ranging from 300kPa to 400kPa (for 1-bar boost).
    Note that DeltaMAP = gauge rail pressure when MAP=BARO (i.e. MANVAC=zero).
    Sep 2010
    Ok, however still a couple points of confusion...
    In the file that I got for my delta map that I already posted. I was told that came from an LS2 bin. (fine because that's what I need)
    However it doesn't match up at all with the spreadsheet. I don't think that spreadsheet can help me. I'd rather just manually calculate what I need on my own, can you give me the formulas with an example to set my IFB?
    I understand the formula you just gave me to find out what they are when I start going into boost. Is it safe to assume my rail pressure (assuming my pump can keep up) will stay the same at 4 bar? If that is the case I believe the formula you've give me above will work.
    The problem with the file I posted, is that if that's from an LS2 the LS2 has a a FPR at the manifold right? I'm getting confused here as to what will specifically work for my application, sorry.
    I'd like to email the files that I have to you if I could.
    Sorry, I missed post #15.
    Trucks usually have the FPR at the manifold/rail... in this case DeltaMAP stays constant at 400kPa (the difference between rail pressure and MAP).
  1. Moving from Vortec MPFI poppet design to EV6 injectors
    By onegonewild in forum Gen IV V8 Specific
    Last Post: December 10th, 2010, 09:55 AM
  2. EV6/LS2 Injectors in 98 L31 Vortec
    By onegonewild in forum Gen III V8 Specific
    Last Post: March 20th, 2010, 08:44 AM
  3. Anyone tuned a LY7 (Acadia, Outlook, CTS, G6)
    By duramax2500hd in forum General (Petrol, Gas, Ethanol)
    Last Post: August 15th, 2009, 07:25 AM
  4. LS2 GTO with Procharger P-1SC-1 52lb Injectors help
    By kooassi in forum Gen IV V8 Specific
    Last Post: April 24th, 2009, 01:06 PM
  5. LS2 injectors ?
    By yellowC6ohio in forum Gen IV V8 Specific
    Last Post: January 3rd, 2008, 11:24 AM
