Results 1 to 6 of 6
Thread: 90mm TB idling at 3000rpm
    Jul 2008
    Default 90mm TB idling at 3000rpm
    Ok trying to help a mate tune his car, it has a 226 234 113 cam and have just put a 90mm Pro Comp throttle body and TPIS 90mm lS6 manifold.
    I cannot stop the thing from spiting the IAC valve out of its housing (It comes all the way out where we have to remove it and put it back together then reinstall. It also upon firing idles at 3000rpm and will not settle. Please find attached a log and the tune. I have tried many different things to stop it but can't seem to make it idle normally.
    Jason COS5 Speed Density 2003 model ls1 manual_0012.tunJason 90mm throttle idle.efi
    Apr 2008
    sounds a mechanical issue with the TB
    Regards,
    Odd Boy
    Lifetime Member johnv's Avatar
    Jan 2005
    Or manifold not seated properly, or maybe a vacumme or breather hose problem.
    usually cammed cars struggle to get enough air at idle, sounds like you have way to much. is the throttle blade cracked open to much when on the throttle stop ?
    is TPS reading zerrow when throttle is closed, may need TPS reset.
    Back yard boost
    347+ T76 = 770 rwhp 10.96 @ 135 mph
    Junior Member SirNemesis's Avatar
    Dec 2007
    If the IAC is spitting the needle, perhaps it is the wrong IAC? It shouldn't do that as the throttle body should physically stop it.
    Oct 2006
    Sounds like a manufacturing error in the TB to me. Measure the distance from the IAC valve mounting face to the seat in both TB's to confirm.
    The Tremor at AIR
    Jul 2008
    All sorted guys, was a problem with the blade and the IAC.
  1. Idling at -5 degrees timing=$ thrown away
    By killerbee in forum Duramax LLY
    Last Post: August 12th, 2009, 02:58 PM
  2. AutoMAF wierd Idling Issues
    By kwhiteside in forum Gen III V8 Specific
    Last Post: July 15th, 2009, 01:20 AM
  3. Car reduced power mode/dies after idling with A/C on for a bit
    By Earl H in forum Custom Operating Systems
    Last Post: June 2nd, 2007, 07:13 AM
  4. A/C Idling extremely rough
    By Highlander in forum General (Petrol, Gas, Ethanol)
    Last Post: October 28th, 2006, 11:10 AM
  5. Anyone with a 90mm TB inside please
    By turboberserker in forum General (Petrol, Gas, Ethanol)
    Last Post: June 17th, 2006, 03:59 PM
