Results 1 to 10 of 14
Thread: can't flash tcm
    Nov 2008
    Default can't flash tcm
    I got a new tcm from gm. Now truck is in limp mode and no speedo. When I try to flash it I get a message" File size can't be determined" Any Ideas? Or do I have to take it to the dealer.
    Is it "file size can't be determined" or is it "flash memory size can't be determined".
    If it is "flash memory size can't be determined", then you may be able to get it going if it is a 5 speed or early 6 speed (pre-2009) by full-flashing it.
    But if it is a late model (2009-2010) 6 speed, since FlashSCan does not support full flashing you would probably need to take it to a dealer to get the most up to date OS programmed into it.
    If the error really is "file size can't be determined", then can you please provide some more context about when the error occurs and what you were doing in the software immediately before the error occured.
    Nov 2008
    It is an 07 Tcm that I got new from gm. I'll have to double check exactly what it said. I can read it just fine. I have tried full flashing it but I don't have any of the correct os to cal only flash it.
    Oct 2004
    After you read the calibration does it show in the Tune Tool with tables, or is it indicating it is an unsupported TCM? What sort of TCM is it incidentally
    (i.e. assume a T43)?
    Andrew
    EFILive Crew
    Jan 2008
    Did i miss an update? we can full flash our 6speeds now?
    Jan 2006
    I thought calibration only on ones with bosch ecms except 09+ ?
    04 LB7
    2010 LMM
    2015 LML
    You will need get the TCM flashed with GM's TIS first, I have no idea what OS is in those TCM's when new, usually GM don't supply new computers with anything functional in them.
    Jan 2008
    so i take it that we can't full flash 6 speeds yet?
    No and probably won't happen due to the reasons discussed in the past.
    Jan 2008
    Whoa! what?! Please PM me i must have forgotten the location of this discussion or missed it completely.
  1. Full flash a g8 gt tcm with a 2010 camaro tune?
    By b18cls1 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: August 3rd, 2010, 02:48 PM
  2. TCM dead after flash
    By minytrker in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: December 4th, 2009, 03:24 PM
  3. Another TCM dead after re-flash
    Last Post: December 4th, 2009, 12:52 PM
  4. trying to full flash tcm
    By j-man345 in forum Allison 5 & 6 Speed
    Last Post: August 12th, 2009, 03:03 PM
  5. Serious problem with TCM flash
    By chrleb2 in forum Allison 5 & 6 Speed
    Last Post: July 7th, 2009, 08:51 AM
