Results 1 to 7 of 7
Thread: 06 1500 hd 6.0 wont spin tires
    Dec 2009
    Default 06 1500 hd 6.0 wont spin tires
    i have been tuning a friends 06 6.0 and it looks like i have all the torque reduction and abuse managment tables correct, can anyone tell me wich tables i have to change and to what to get this truck to spin tires?
    Aug 2008
    While stomping on accelerator, an aggressive right or left hand turn will help...
    My truck is a 1500 with a 6.0 and it will spin the tires only when it wants too...Of course it doesn't help that it has heavy 20" stock wheels & tires...
    FLASHSCAN V2 & AUTOCAL
    Aug 2010
    Take a look in the Traction Control folder of the Engine Calibration - especially B6605 - if TCS is active - will probably be pulling a lot of timing out to reduce torque output.
    Regards,
    Taz
    Dec 2009
    Wink
    Thanks I'll try it out, and I'm going to have to test it out in the rain to get it to spin I'm thinking
    Mar 2009
    Also don't forget the BTM enable and disable RPM's otherwise it will never spin the tires with brakes applied. Should be in torque limiting> parameters. B0401 and B0402 I believe.
    Oct 2006
    If I put mine against a tree , its wet out and stomp it it will spin the tires . :-}
    No really mine will , (3.73 , 87 octane) but I have a small cam and long tube headers .
    1500 HD is a heavy load to get moving , before I got the Yokohama tires it would smoke them till you stopped it (dual stripes , not one side), with the Trans-Go it will shift and never miss a spin .
    When it was stock not so much , cam and headers make a huge difference .
    Note: Long tubes on a HD are complicated and had a real good Exhaust guy to make them work for me .
    I suppose if you tuned for 93 octane , you can get a few more ponies and could get some scratch .
    2006 Trailblazer
    Aug 2008
    Maybe an aftermarket Torque converter, 2500 or higher stall speed...
  1. Where to start? 09 GMC 1500 5.3 6 spd
    By LaMountain in forum Petrol / Gas
    Last Post: August 18th, 2010, 08:01 AM
  2. tranny in 2004 chevy 1500 4x4
    By justin123 in forum Gen III V8 Specific
    Last Post: January 16th, 2010, 02:28 PM
  3. AFM-1500 serial comms...
    By Redline Motorsports in forum General
    Last Post: November 26th, 2009, 10:07 AM
  4. 04 1500 and lean cruise
    By chrleb2 in forum Gen III V8 Specific
    Last Post: April 4th, 2008, 03:56 PM
  5. Tuning for new larger tires. Need Help
    By jamesbond2509 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 30th, 2005, 02:11 PM
