Results 1 to 2 of 2
Thread: Converting Carb to MPI EFI system
    Apr 2009
    Default Converting Carb to MPI EFI system
    Hi there every one
    its been a long time since ive posted my last post.
    well I have a new job which is an instructor in Automotive Mechanics school, and my project for this year is to convert a Carb engine (Mopar 318 1990 and a small block chevy 350 1990[ TPI] into a Multi port injection{MPI} EFI system. I am really lost in finding a cheap and not easy method which I was looking for is an MPI intake manifold, I found some but the fitting is the problem, the main issue that I am going to drill the original manifold and get the Megasquirte EFI system (injectors and sensors) and install them, and I am thinking if it is possible to get any other vehicle's ECU and use EFIlive or any other method to remap this ECU and make it work with my setup. By the way there are many BOLT on MPI systems which are $2000+ which u can't let the students work on and the MegaSquirte (as the Tech support said) won;t give you or store DTC codes which we use to make the Students trouble shoot the Faults
    I hope that you guys gonna share your knowledge and thoughts with me
    thanks a lot
    Best regards
    Oct 2006
    2006 Trailblazer
  1. Anyone Do a Carb Conversion.
    By TBMSport in forum E37, E38 & E67 PFI ECM's
    Last Post: September 19th, 2010, 08:39 AM
  2. HELP!!! Converting Efi Live to HPTuners file!
    By 06x6spdGTO in forum General (Petrol, Gas, Ethanol)
    Last Post: April 12th, 2010, 11:46 PM
  3. 2001 5.7 v8 mpi ohv
    By Spuco in forum Vortec V6/V8 Specific
    Last Post: February 28th, 2010, 04:11 PM
  4. 98 s10 converted to carb but still has 4l60
    By minytrker in forum Vortec V6/V8 Specific
    Last Post: August 30th, 2007, 12:39 PM
  5. Trying to use 4L60-E with 4-barrel carb
    By towline_5 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 22nd, 2007, 06:33 AM
