Is there an OS that can be loaded into the E38 that will remove the 512 GPS MAF restriction?
That's it, nothing too hard to answer.
I'm asking in connection with my 2.5 BAR MAP and E-Force supercharger.
If the tune is scaled, all of the tables for air and fuel need to be scaled by 25%. If the tune is unscaled, then the PE table is "adjusted" to cover the area above the MAF table.
Elmer
