Hi Guys, Ive had a good look at previous threads, also in General, but here is my problem.
My RR is working fine (after reading joe car threads) and now have an issue with 2 bar OS. When I open Scan tool, (with RR open and connected in Tune Tool) it asks for VIN no. and my RR has these all set at zero. It asks me if I want to enter new VIN (Yes or No) If I select No, then it only shows about 42 pids, with only approx 10 activated (and not the ones I want). If I select Yes, and enter new VIN, then it shows approx 300 PIDs and I can set up my PIDs how I want and Save them, and then set up Dash page, so that I can track and save captures, and in particular track in Tune Tool which load point I am at. BUT, as soon as I hit the green button to Connect, it switches to a basic dash page and my PIDs go back to about 40 total. What the......
The main thing I am trying to do is use the Dynamic Cylinder Air so that I can see where Im at in my Spark tables, but DYN CYL AIR disappears when I hit the Connect button.
This is the first time I have used my RR with 2 bar setup. It had no probs with 1 bar OS.
Is it a 2 bar issue, or am I doing something wrong.
I have spent all day messing with all different possibilities. I have tried with std pcm on bench (non RR) with std OS and it seems fine. I havent reflashed 1 bar OS into RR to proove that 1 bar is ok since last time yet, but that may be next.
Any help much appreciated.
