Page 7 of 7 FirstFirst ... 567
Results 61 to 66 of 66
Thread: Idle (Transition) Tuning
  1. #61
    Oct 2005
    Is there anyway to tune out the RPM drop condition you get when shift from Park to Reverse on a A4 it is like a 300 RPM drop and it recovers quickly?
  2. #62
    Oct 2005
    Yeah Id check out the idle tuning and transition stickies. You might need to do some logging and tweaking in the desired air flow IAC parked etc tables.
    You can certainly tune it out no problem.
    2014 VF SV LS3 Maloo.
  3. #63
    Oct 2003
    Quote Originally Posted by 94SS
    Email GMPX or post up. There use to be a thread/quiz on this - with the anawer!
    joel
  4. #64
    Oct 2004
    Quote Originally Posted by bink
    joel
    Think this is the thread http://efiforum.iqd.co.nz/showthread.php?t=737
    Andrew
    EFILive Crew
  5. #65
    Oct 2003
    Quote Originally Posted by Tordne
    That's it!! Thanks!
    joel
  6. #66
    Junior Member ws6togo's Avatar
    Mar 2005
    Default WOW...lots of information
    What is the very first step a new guy should do? One of the first comments in this post is that a resonable tune be done. Should I just use one of the stock pcm tun files and flash my ECU or should I try to work the current ECU files? Kinda need a starting point. Does anyone have a decent range of what each of the PIDs should be? Sorry to sound so new....BUT I AM.
    '00 Pewter TA WS6 12.6@111 on street tires 1.87 60'
    PERFORMANCE: BG Ram Air, Lid, K&N, MSD 8.5 wires, NGK TR55's, 160*
    SUSPENSION: BMR-STB/SFC/PHR, UMI LCA's
    DRIVETRAIN: rebuilt 4L60E. 3000TCI, Hayden Trans Cooler, Yukon 3.73's, TA girdle
    TUNING: EFILive
    No runs after engine upgrade
    Newest mods:LS6-intake/heads/ported oil pump, 28lb injectors, Comps-918's, Comps 224/230 .581/.592 114 cam, Dynatech LT's, Rollmaster chain.
  1. Idle/Idle Transition Tuning
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 11th, 2007, 05:10 AM
  2. Tuning idle transition with OS5
    By oztracktuning in forum Custom Operating Systems
    Last Post: August 2nd, 2006, 01:15 AM
  3. Stock maf = perfect idle. Big maf = unstable idle. Any tuning suggestions?
    Last Post: July 11th, 2006, 03:58 PM
  4. Dirk Diggler, Idle Transition
    By lplott in forum General (Petrol, Gas, Ethanol)
    Last Post: December 2nd, 2005, 02:41 AM
