Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: MAP or MAF for timing
    Nov 2005
    Default MAP or MAF for timing
    Does the Duramax use the MAF or MAP for timing? Looking at B0901 on my stock tune it is set to MAP. I would have thought it should be using MAF. Please forgive my ignorance.
    Dave, all the GM files I've seen are using MAP (actually Baro), reason?, not sure.
    You can confirm this by the fact the A,B,C load points for the MAF are all set to 32 as well as the MAP selection.
    Well, thinking about it, if set to Baro that gives you 3 timing tables to compensate for Baro differences, but if you set it to MAF you could have 3 timing tables based on load.....that to me sounds like a much better option as far as when these engines are being pushed way above the power levels GM would have tuned for, the only problem is you then loose Baro timing compensation because there is no Baro based timing table.
    That might very well be an issue for someone who lives up in the clouds.
    Dec 2005
    Use Injection Timing MAP "C" as it is in effect above 162 degrees.
    The other MAPS "A" and "B" are used for lower temps and then use multipliers for BARO and Fuel Temp to further alter timing if necessary.....but the multipliers do not effect anything over 132 degrees and the factor is ZERO so it does not effect timing anymore.
    If it rattles you have too much timing..........or you might want to move pilot timing closer to main injection timing..........use PILOT Timing table "C" for 155 degress to 162 degrees and "D" for 162 degrees and over.......
    You would be surprised how different the truck reacts and the motor reacts to pilot timing........
    If you need any help you have my email and you can PM me,
    T NY
    www.mscservices.net
    Nov 2005
    Awesome, Thanks. Now if it would quit snowing.
    2003 CC 3500, LB7
    EFILive and lovin it
    Quote Originally Posted by GMC-2002-Dmax
    You mean, you can make it sound like a Powerstroke
    Jan 2005
    Quote Originally Posted by GMPX
    That's "Powersmoke"
    Lifetime Member Max Power's Avatar
    Nov 2005
    You mean "PowderStroke"
    09 LMM Duramax
    "Powerjoke", keep em coming, where a happy GM family around here
    Nov 2005
    Hey did you hear Ford found the problem? Yep, they even circled it!
    09 LMM Duramax
    Talking
    Found On Road, Dead.
  1. Billet LT1 Timing Cover - Clears Double Row Timing Chain
    By S10Wildside in forum Conversions / Aftermarket Parts
    Last Post: November 17th, 2009, 01:15 AM
  2. EGR timing
    Last Post: September 11th, 2008, 03:58 PM
  3. timing vs AFR
    By odd boy in forum General (Petrol, Gas, Ethanol)
    Last Post: July 30th, 2008, 11:59 AM
  4. Timing
    Last Post: March 2nd, 2006, 11:59 AM
  5. Log timing
    By purrvert in forum General
    Last Post: February 19th, 2006, 04:27 PM
