Results 1 to 5 of 5
Thread: when i switch tunes it kills truck
    Dec 2010
    Default when i switch tunes it kills truck
    i have efilive + edge insight cts monitor. i have dsp5 by nick and when i switch off of anything except tune 1, my truck dies. but tune 1 seems to run just fine. any help? or need more specifics?
    Lifetime Member vortecfcar's Avatar
    Apr 2007
    The tune is set to serial, and all of the DSP5 tables are populated like they should be. I don't see anything in the tune that should cause this.
    Any updates Nate?
    Nick
    Dec 2010
    for some reason it wasn't set to serial on mine. when i went in to switch it, SOMEHOW all the fuel tables got set to 0. I've no idea how/what i did, but that did it, so i just downloaded the tunes from email and started fresh and was very careful not to change anything. now its on there and works like a charm!
    but... i've got one more question while i've got ya. at the top of most of my gears, it feels like my truck is lagging or, wanting to stick in that gear and not shift, so i've got to let off the accelerator a little bit to get it to shift... normal driving is fine, no problems at all, just when i'm into it it gives me these fits. thanks Nick
    Nate
    Apr 2010
    What rpm is this occuring? Have you messed with the transmission tuning? If the shifts in the trans is set too high it'll hang there til the truck hits the mph then shift. Or until you let off the peddle and it see's a lower throttle position, say 70%. Then at that 70% throttle position if the truck is above that certian speed in the trans shift table then it shifts. sounds technical...really isnt.
    edit: also what is your rpm limit on the truck?
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Quote Originally Posted by nateneill View Post
    Nate
    I know this is an older thread, but for what it's worth that sounds exactly like a fuel filter that needs to be replaced, not so much a transmission tuning issue.
    Peace Through Torque
    Punisher Performance DSP5 Tuning, PPE Dual CP3's, 68mm Fleece Cheetah, Punisher Built trans w/ Suncoast Parts, Airdog 165, SoCal 100% Overs, ARP Studs
    2013 NHRDA Sportsman World Champion
    www.PunisherPerformance.com
  1. how to switch tunes to DSP5????
    By browneflatwork in forum General (Diesel)
    Last Post: February 28th, 2011, 10:27 AM
  2. bbl cant load tunes to truck???
    By blackbeast ss in forum Black Box Logging
    Last Post: June 4th, 2010, 05:28 PM
  3. Going from DSP2 switch to DSP5 switch
    By Dmax15 in forum Duramax LB7
    Last Post: February 23rd, 2010, 03:25 PM
  4. Replies: 50
    Last Post: March 15th, 2009, 04:00 PM
  5. Taurus fan kills idle, How to tune?
    By DaleMX in forum General (Petrol, Gas, Ethanol)
    Last Post: September 3rd, 2005, 06:34 PM
