Results 1 to 10 of 14
Thread: Looking to unlock E38 ECM flashed with HP Tuners
    Oct 2003
    Default Looking to unlock E38 ECM flashed with HP Tuners
    I have an E38 ECM which has been flashed/locked with HP Tuners. Who can unlock this ECM
    or is it toast? Thanks Jim
    08 Z06
    Aug 2006
    Hi, not sure were ur located, but ross (pcm tech) will most be able to help u his in melb austraila, shoot him email if he hasn't shut up shop for xmas. regards Jason
    Oct 2004
    Generally a locked ECM can only be unlocked if you know the lock key. Ross (GMPX) can unlock them but I'm assuming you're going to be in the US in which case shipping to Australia might be more expensive than buying another E38 ECM.
    Andrew
    EFILive Crew
    Oct 2003
    Thanks for the information. I was not sure if it could be done. Jim
    08 Z06
    Have someone with HPTuners unlock it? But if you have to pay for credits to do so, its cheaper to buy a new E38 and not hassle with it.
    That won't work unless it was the actual person that locked it, any other person using EFILive or HPT will be in the same boat. It's not the HPT custom OS that is the problem.
    Apr 2008
    where is ur location? if you r in the middle east, I can return it stock for you to preserve people rights.
    Regards,
    Odd Boy
    Lifetime Member Chalky's Avatar
    Sep 2003
    I believe Jesse, Wait4me, can unlock a locked pcm? Last I knew he could!
    2015 Z06 A8
    Ah I thought it was a COS issue, not a seed/key lock. If thats the case, then either the person/cable needs to be used to unlock it or a new ECM.
    Feb 2006
    I've done a entire write of a clean OS onto an existing hptuned e38 before. Obviously the seed/key were still intact.
  1. Replies: 7
    Last Post: December 6th, 2010, 01:55 PM
  2. E38 ecm failure
    By shane in forum Gen IV V8 Specific
    Last Post: February 19th, 2010, 11:19 PM
  3. ECM Lock and unlock
    By markgammel in forum General (Petrol, Gas, Ethanol)
    Last Post: October 7th, 2007, 02:59 AM
  4. Flashed COS3 now get PCM unlicenced message !
    By johnv in forum General (Petrol, Gas, Ethanol)
    Last Post: July 22nd, 2007, 11:13 PM
