Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Looking to unlock E38 ECM flashed with HP Tuners
  1. #11
    Mar 2007
    Quote Originally Posted by Tre-Cool View Post
    I've done a entire write of a clean OS onto an existing hptuned e38 before. Obviously the seed/key were still intact.
    I am guessing that this was done using a Tech II?
  2. #12
    Aug 2004
    If they use a custom os then it will be locked. The only way to unlock them is to send me the computer and i can open it up and read out/put it back to stock for you and fix the seed/key area.
    I only charge $35 + shipping for this service. It will save you from having to purchase a new e38.
  3. #13
    Feb 2006
    nope. just did it in efilive. it definetly wasnt a standard calibration as i could suck it out but not see it.
    so i just did a entire write with the factory cal and went from there.
    attached is the file i sucked out. maybe the efi boys might be able to take a look at it.
    And the factory cal i wrote back in.
  4. #14
    Obviously we can't support HPT's custom OS's in our software.
    However, the check we have in the software now that confirms the OS you are about to flash in to an E38 is not about to kill it also includes the HPT OS's numbers for when you want to return a non locked ECM back to a factory OS. So if you do come across these and need to return it back to a factory OS, just choose a file and try to flash, if it's a mismatch we will tell you.
  1. Replies: 7
    Last Post: December 6th, 2010, 01:55 PM
  2. E38 ecm failure
    By shane in forum Gen IV V8 Specific
    Last Post: February 19th, 2010, 11:19 PM
  3. ECM Lock and unlock
    By markgammel in forum General (Petrol, Gas, Ethanol)
    Last Post: October 7th, 2007, 02:59 AM
  4. Flashed COS3 now get PCM unlicenced message !
    By johnv in forum General (Petrol, Gas, Ethanol)
    Last Post: July 22nd, 2007, 11:13 PM
