Follow up to this thread....
There is an axis error between KPA Delta 308 and 348......also if these are the correct break points shouldn't it also be corrected in the "Injector Flow Correction" table as well????
In addition if an older file that we started with has value based upon the old breakpoints; when that file is opened up with the software update will it normalize the new breakpoint values???
Howard
