Page 5 of 5 FirstFirst ... 345
Results 41 to 42 of 42
Thread: Mislabeling: IFR & IPVA Row Labels
  1. #41
    I guess I'm trying to confirm that the IFR table we are using in the "older" scaled table is correct since that OS does not have the newer axis change. I went and opened a stock ZR1 file but all the axis are the new ones now! Just didn't make sense that at 400 KPA the value should be 7.11
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
  2. #42
    If you previously did not change the IFR then it is still correct.
    If you previously changed the IFR based on looking up the old axis, then it needs to be redone using the new axis.
    What should the the 400 kPa value be...?
  1. Billet LT1 Timing Cover - Clears Double Row Timing Chain
    By S10Wildside in forum Conversions / Aftermarket Parts
    Last Post: November 17th, 2009, 01:15 AM
  2. VE Table MAP 30 row help
    By ViolatorTA in forum General (Petrol, Gas, Ethanol)
    Last Post: August 7th, 2006, 03:56 PM
  3. Map Kpa Labels For 2bar
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 7th, 2005, 04:18 PM
