Results 1 to 2 of 2
Thread: FAILED RE-FLASH p10
    Apr 2007
    Default FAILED RE-FLASH p10
    UPDATE--Anyone having failed re-flashes on Trailbazers, Colorados or any
    IL6 application where the re-flash stops about 1/3 of the way and then locks up--Car then won't start and is completly dead
    I had had a friend with a TECH II read the ECM and it says to unplug the following fuses:
    Under the rear drivers seat fuse box--- # 6 and # 51--
    #6 is for the brake light and # 51 says LGM/DSM ( don't know what that actually is)
    Unlike most GM applications where the radio---amp---accessory--- Bose---aux. or Info fuses are pulled----Have no idea why #6 and #51 are correct but must have some hidden reason why it interupts communication
    YES--flash worked and tune successfully downloaded !!! 99.99% the ECM is not fried and the tune can be re-covered---
    Try with V8 before you bother pulling any fuses, I couldnt flash my P10 with V7.5 but fired up V8 and it recovered the calibration and flashed perfectly without touching any fuses.
  1. failed flash
    By pdasterly in forum FlashScan V2
    Last Post: January 6th, 2010, 05:21 PM
  2. P10 high speed read/flash issue
    By ScarabEpic22 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: September 17th, 2009, 10:15 AM
  3. failed flash
    By 69camaro5speed in forum Allison 5 & 6 Speed
    Last Post: January 8th, 2009, 01:58 PM
  4. Help flash memory test failed
    By modpcm in forum FlashScan V2 BB Logging
    Last Post: June 13th, 2008, 10:33 AM
