Its a regular US factory 09 C6 M6 tune
There is no main fuel table. GM has been running a "virtual" VE (airflow model = "fueling" table) table since 06. VVE tables run a set of complex coefficients to generate a virtual VE surface that the ECM calculates on the fly.
Search on virtual VE or VVE tuning tutorial by Swingtan and that'll run you through getting it tuned if you want to get into the fueling that deep, but it depends whether you are aiming for an SD tune or want to stick with closed loop running on a MAF and simply do PE for WOT fueling.
Cheers
