I can try that so power it up before connecting to pc or v2
It must be powered up to connect.
LC-1 WBO2
Yup still donte work. Innovate must have one damn of a holiday scheduled I called them yesterday and today, no answer argh.
Yup finally got it back after fighting with them. But it was DOA so they sent me another unit and it works. Ok now to hook up to laptop do you need a null modem adapter? I know to the V2 you do but it still won't connect to laptop, so was wondering if you need a null modem adapter or if my serial to usb adapter isn't working.
Tim,
Connecting LC-1 to Laptop (for running LM Programmer software):
LC-1 serial OUT -> Laptop
LC-1 serial IN <- terminator
Connecting LC-1 to FlashScan V2:
LC-1 serial OUT-> null modem adapter -> V2
(the terminator is the 2.5mm blank stereo plug)
You must set the V2 serial comms setting to Innovate Wideband.
You can change the settings in the V2.
F4> F1> F1
LC-1 WBO2
Josh, yes, even if you're doing passthru... you can set the serial settings either thru S&T, or from the V2 keypad as mr.prick pointed out.
