Results 1 to 10 of 11
Thread: need a log file for M6 with after market clutch while fast shifting
    Lifetime Member wesam's Avatar
    May 2010
    Default need a log file for M6 with after market clutch while fast shifting
    Need a log file for M6 with after market clutch while fast shifting
    thanks in advance
    EFILive Tuner
    Jul 2008
    wesam:
    What exactly are you looking for? I have dozens of actual log files. I don't know if the LS7 clutch qualifies as 'aftermarket', but let me know.
    I shift fast, but not like I am racing..Here is quick screen-shot of a part-throttle 3rd-4th gear shift from a few weeks ago. Let me know if you need the entire log file..
    May 2010
    Thanks a lot Shawn i need some thing better than the LS7 clutch i have it now and i feel that its slipping so i want to compare what happened after releasing the clutch with any after market clutch
    i like the way and the smoothness of the LS7 and don't want to put some thing stiff but i have to now coz I'm in the 520+ whp area
    EFILive Tuner
    Jul 2008
    Gotha..
    Yes, you certainly have upped the HP on that vehicle!
    Hopefully someone can post a log. It gets a little slow this time of year. Hardly anybody is driving their vehicles in the U.S. right now..Very cold and snowy.
    Maybe one of our 'down-under' friends can help out...
    Junior Member SirNemesis's Avatar
    Dec 2007
    I don't think my quick shifting is very impressive, but this is the best I have. Hopefully it is useful to you.
    shifts.efi
    shifts2.efi
    Senior Member Sid447's Avatar
    Jul 2005
    Quote Originally Posted by wesam View Post
    thanks in advance
    If you are running any Holden derived M6,
    with any clutch assembly and you haven't modified the factory clutch fluid line (it has an in-built restrictor to purposely limit the speed at which the clutch will mechanically work) ....then your problem isn't tuning, it's mechanical.
    There is a mod-kit available for this, which cures the problem.
Name:	Clutch Hyd-line.jpg
    May 2010
    what i noticed and i want to know if it will be solved by a good after market clutch that after each shift ( after releasing the clutch ) the speed will go up then down then up again as we can see in each 0.5 sec after shifting in Sirnemesis logs
    EFILive Tuner
    May 2010
    Quote Originally Posted by SirNemesis View Post
    shifts.efi
    shifts2.efi
    nice car in the second Log what kind of power it put down ?
    as i can see its FI car
    EFILive Tuner
    Dec 2007
    It was putting down about 400rwkw. Standard 6L with a big turbo, but that run was actually the end of it.
    I'm building a 390ci engine at the moment.
    1985 Volvo 240 || LS2 || 4L80e || S488 Turbo
    May 2010
    i saw 4 degree of Knock in your last run what cause it
    as i can see the timing is low and your A/F is good ( never exceed 11.6 )
    EFILive Tuner
  1. Log file help.
    By aaronr in forum Gen IV V8 Specific
    Last Post: September 21st, 2010, 03:27 AM
  2. No DTC's in log file
    By spandit in forum Black Box Logging
    Last Post: September 16th, 2010, 03:51 AM
  3. Opening a log file?
    By jfpilla in forum General
    Last Post: June 27th, 2007, 02:24 PM
  4. Would someone be willing to look at a log file?
    By stigmundfreud in forum Gen III V8 Specific
    Last Post: May 6th, 2007, 09:47 AM
