For some reason my virtual dash doesn't work. All the guage names have lines drawn through them. Is there a way I can reset them or something?
You need to select the appropriate PIDS.
Press F8 and select the corresponding PIDS from the list.
09 LMM Duramax
Can I select all of them or just should I just select the ones I need?
Try choosing the default setting. You don't want to select them all.
09 LMM Duramax
Thanks. I went in and manually selected them. It works.
