I'm having alot of trouble getting my truck to accept a tune.. i've never ran into this before and i've used the V2 since it came out years ago. What will happen is when I go to flash in a cal. it will get to the part that says "Erasing ECM flash memory... (please wait up to 2 minutes)" and it will wait all 2 minutes and then won't continue.. I can get it to work but I have to jack with it for sometimes up to an hour to get it to work. This includes checking and rechecking all my connections, closing and opening the tune software as well as restarting the computer.. i'll do all this stuff off and on and finally it will work like normal once, never back to back. I haven't had this truck that long and I haven't had these problems before so that got me wondering. I updated all the software, firmware etc.. not long ago so that should be good to go. Could this be something to do with the truck? It is a 2008 LMM duramax, no DSP yet.. I plan to setup the DSP5 but I want to get this issue resolved first. Also nothing extra is plugged in to any of the outlets and everything in the truck is in the "off" position. I included a copy of what the screen says with it won't flash..
Thanks guys.
17:50:57.516: Scanning for EFILive FlashScan V2 HAPI
17:50:57.529: Autodetect interface ...
17:50:57.696: Interface firmware version: 2.7.2
17:50:57.697: Connection to [FSV2] interface is OK
17:50:57.706: Interface firmware model: FSV2
17:50:57.712: Interface firmware version: 2.7.2
17:50:57.718: Interface firmware date: Oct 25, 2010
17:50:57.724: FlashScan serial number: 003589101794
17:50:57.730: FlashScan license number: 003498373414
17:50:57.741: Disconnecting ...
17:50:58.491: CAN-VPW Bridge Deactivated
17:50:58.493: Disconnected
17:50:59.078: Scanning for EFILive FlashScan V2 HAPI
17:50:59.090: Autodetect interface ...
17:50:59.262: Interface firmware version: 2.7.2
17:50:59.265: Connection to [FSV2] interface is OK
17:50:59.274: CAN-VPW Bridge Activated
17:50:59.334: Current protocol set to: "ISO 15765 CAN"
17:50:59.337: Autodetect PCM...
17:51:01.344: PCM not detected.
17:51:01.347: Autodetect ECM...
17:51:01.361: Connection to ECM is OK
17:51:01.364: Autodetect TCM...
17:51:01.379: Connection to TCM is OK
17:51:01.387: Current protocol: "ISO 15765 CAN"
17:51:01.397: Interface firmware model: FSV2
17:51:01.405: Interface firmware version: 2.7.2
17:51:01.413: Interface firmware date: Oct 25, 2010
17:51:01.419: FlashScan serial number: 003589101794
17:51:01.425: FlashScan license number: 003498373414
17:51:01.445: Getting status...
17:51:01.667: Status: OK.
17:51:02.382: Preparing ECM for reflash...
17:51:02.395: ECM seed is: $AB19
17:51:02.397: Unlock attempt 1 of 1
17:51:02.515: Initializing ECM...
17:51:03.834: Request GM operating system...
17:51:03.851: GM operating system: 12628594
17:51:04.632: Request serial number...
17:51:05.458: Serial number: 864802002900
17:51:07.219: Reflashing ECM's memory...
17:51:12.657: Erasing ECM flash memory... (please wait up to 2 minutes)
17:53:15.664: ECM flash memory erased OK
17:53:27.763: Reflash failed, aborting...
17:53:27.767: Total time: 02:16
17:53:27.769: Data compression achieved: 0.0%
17:53:27.783: Attempting to reboot ECM... (please wait up to 8 seconds)
17:53:30.889: Waiting for ECM to complete reboot process... (Retry 1 of 8)
17:53:32.892: Waiting for ECM to complete reboot process... (Retry 2 of 8)
17:53:34.897: Waiting for ECM to complete reboot process... (Retry 3 of 8)
17:53:36.902: Waiting for ECM to complete reboot process... (Retry 4 of 8)
17:53:38.906: Waiting for ECM to complete reboot process... (Retry 5 of 8)
17:53:40.912: Waiting for ECM to complete reboot process... (Retry 6 of 8)
17:53:42.915: Waiting for ECM to complete reboot process... (Retry 7 of 8)
17:53:44.919: Clear emisison related DTCs...
17:53:46.954: Autodetect interface ...
17:53:46.972: Interface firmware version: 2.7.2
17:53:46.975: Connection to [FSV2] interface is OK
17:53:46.978: Autodetect ECM...
17:53:48.992: ECM not detected.
17:53:50.238: Reflashing completed successfully
17:54:10.913: Done!
