I see in COS 5 There is an option to change type of knock sensors B1402, Can I use the LS2 type and rewire to 411 pcm as shown?
I couldnt get it to work but that isnt saying much. AFAIK the necessary hardware isnt in the pcm to run these sensors properly.
The Tremor at AIR
24x LS1 PCM on Early Small-Block Chevy and LT1/LT4
http://www.eficonnection.com
Just wondering if someone could help on the knock sensors, I realise that the higher the number the less sensitive they are, but what is the mg on the top of the table? where the numbers 100/200/400 etc?
Cheers
