Results 1 to 9 of 9
Thread: Custom OS's on the DuraMax?
    Junior Member m396 #00-011's Avatar
    Oct 2003
    Default Custom OS's on the DuraMax?
    Will we see anything on this in the future?
    Many people I know with the DuraMax's and the various hotbox's like to switch through the programs. Can the valet switch on the Custom OS's be used in such a manner?...?....?
    As if your plate wasn't full enough.
    Jason Woolverton
    2000 Mallett FRC
    2003 Silverado SS
    Mallett 396's Garage
    Lifetime Member Max Power's Avatar
    Nov 2005
    One step at a time
    It sure would be nice though
    09 LMM Duramax
    Plate is mighty full to even think about custom O.S's for the Dmax yet.
    But don't worry, the Duramax beta testers were on to that one in a hurry too. There is other enhancements the Duramax users need first, they will be done before attempting custom O.S's.
    On the fly switching sounds neat enough, but then again, 30 seconds to flash a whole new tune in isn't 'that' bad.
    Sep 2005
    And when V2 comes out, you can keep your "hot" tunes in the glove box
    Nov 2005
    The hot tune is the daily driver
    09 LMM Duramax
    Senior Member Racehemi's Avatar
    Nov 2005
    What happens when larger turbos enter into the equation and the bottom row of a boost table is exeeded? Rescale the MAP sensor?????
    04 2500, LLY/A, 4x4, CC, SB, 285 Toyo's, Amsoil lubes, Access Roll-up Tonneau, ATS Stage 2 trans, ATS 5 Star Converter, Bilstein's, Caltracs bars, Cognito Braces, EFILive, Kennedy Diesel Custom Tuning, Kennedy Diesel headlight harness, Kennedy Dual Lift Pump/Filter combo, Prodigy brake controller, Spa DG 211, Trippin Cyclops overhead gauge mount, , TTS 4" Exhaust, TTS Xtreme Beta, Amsoil Ea filters, Banks CAI
    Lifetime Member bobo's Avatar
    Nov 2005
    I don't see anyone putting on a larger VVT that uses the boost table.
    2005 Twin Turbo Dmax/Allison Ext. Cab Short Box 4X4
    Best 1/4 11.8 @ 118+ on #2 only
    Twisted Diesel Tuning-The leader in Duramax Tuning Services and soon to offer Common Rail Cummins Tuning!
    Bobotune at rocketmail dot com
    Nov 2005
    I was thinking more along the lines of an LB7 and its boost tables, B0504, 5, and 6.
    Nov 2005
    Gotcha. Haven't messed w/ the LB7 stuff much!
  1. Duramax Tuning
    By kurtfromct in forum General (Diesel)
    Last Post: January 13th, 2009, 03:36 PM
  2. 03 lb7 duramax
    By mike37davis in forum Duramax LB7
    Last Post: January 9th, 2009, 03:16 PM
  3. 03 lb7 duramax
    Last Post: January 8th, 2009, 06:39 PM
  4. Duramax Programming
    By GMPX in forum General (Diesel)
    Last Post: December 12th, 2005, 12:04 AM
