Results 1 to 3 of 3
Thread: Could scanning cause shift problems?
    Lifetime Member 87gmc's Avatar
    Apr 2004
    Default Could scanning cause shift problems?
    When im data logging with black box it seems the 1-2 shift are delayed. When not connected to data port it shifts fine. Could the hardware be causing this problem? By the way its on my 99 GMC 5.3L Automatice 4l60 :?:
    Oct 2003
    I've never experienced that kind of problem.
    I'd rather be blown, bored... AND stroked!
    Now: 447 CID (Corvette 427) , ATI Procharger D-1SC Supercharger
    Default Re: Could scanning cause shift problems?
    Quote Originally Posted by 87gmc
    I just can't think of any reason this could happen.
    If you had a separate trans controller on the bus whose shift messages were being delayed because of the scanner then yes, but that is not the case with the PCM doing both.
    GM limit the amount of data the PCM sends back so it has time to actually run the engine and shift the trans.
    Does it only happen when you are actively logging, or just when the unit is plugged in?.
  1. Problems scanning maf Hz.
    By Highlander in forum Vortec V6/V8 Specific
    Last Post: October 2nd, 2015, 12:03 PM
  2. Coan Converter A6 Shift Problems
    By EVI in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 10th, 2010, 08:16 AM
  3. V1 Scanning an LMM
    By rebel7777 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 26th, 2009, 02:40 PM
  4. why 1>2 shift happens at higher rpm than 2>3 shift?
    By 350SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 13th, 2008, 11:54 AM
  5. Disable adaptive shift learning after Shift Kit Install
    By BlackGMC in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2008, 05:49 AM
