Any updates?
Any updates?
08 4X4 3500 mega
Grey haired riders don't get that way from pure luck!
There will be no news of any significance on the 6.7L until the 5.9L tune and scan is complete and released.
I own a blue V2 (licensed for a Duramax), and have an 08 6.7L as well as an 05 5.9L. If you need a cal from either of those let me know. I would be glad to help.
Paul, If you could read your 5.9L truck that would be great.
Just make sure all your software and firmware is up to date:
http://forum.efilive.com/showthread....se-candidate-1
Is he going to be able to read the '05? isn't that an SCI year?
Ah yeah, good point, he needs to see what model ECM it is first. If it's a late 2005 there is a very good chance it's got the right ECM.
Pop the hood and check the label on the side of the ECM, if it says CM - CM849 then you are in luck, if it says CM848 then it's an SCI ECM and you won't be able to read it.
I have a 2010 6.7 when you get to those i will read if needed.
I own the black version I used to tune my old chevy. I now own a 07.5 6.7 If you need any readings from my ECM let me know! I just saw that the 5.9 is out! Now get the 6.7 out please!!!!
I can't believe it took so long for someone to say that LOL.
Andrew
EFILive Crew
Current toys are as follows:
1961 Chevrolet Corvair Monza, 145 H6/powerglide. 85 HP of raw fury.... slow and stock and staying that way!
1969 GMC 2500, 4-53T Detroit diesel/Fuller 10 speed on late model 1500 HD frame
1970 GMC 9500, 6-71 Detroit/Fuller 13 speed, not sure why I bought it, but it sure is noisy!!!
1975 Ford F100 shortbed. Currently undergoing Crown Vic subframe swap and EFI 4.6!!!
1975 Chevrolet Vega, 5.3/200-4R may finish someday, maybe...
