Page 4 of 4 FirstFirst ... 234
Results 31 to 37 of 37
Thread: 6.7L Development roadmap
  1. #31
    Nov 2008
    As in DTC's? Yes that should be possible, but none of the scantool live data will work, it's different between the 5.9L & 6.7L.
    Thank you! Have a friend who needs dtc read on his and I did not know if it would work.
  2. #32
    It works fine, I just tested it on our bench 6.7L ECM (see below). In the scantool connect to it as a "CMB CM849 Cummins" and it'll talk with the 6.7L.
  3. #33
    Nov 2008
    I scanned the 6.7 yesterday and found a couple of codes. I was able to log rail psi, throttle position, and a few other things. Found out his fuel rail valve was popping off. He had it at the dealer numerous times and spent over 4k on it already. This was a quick simple fix. Thank You EFI and I look forward to further developments on the 6.7
  4. #34
    The scanning worked!, I am surprised as the data streams are specific to each ECM type, I didn't think there was any way the 5.9L would match the 6.7L on any account.
  5. #35
    Nov 2008
    Just some of them. Desired FRP was off it seemed. Actual FRP was accurate. TP was accurate. I can't remeber any of the other ones. I did not try reading it, I might go try that. I didn't think it was supposed to work either but, I had to try
  6. #36
    Nov 2008
    So does this mean 6.7 progress will be sped up?
    Sorry...........had to ask
  7. #37
    Not really because we still have to check and confirm every PID, even if some match.
  1. Cummins development progresses
    By GMPX in forum Cummins 5.9L
    Last Post: June 1st, 2011, 02:39 PM
  2. Cummins development progresses
    By GMPX in forum General (Diesel)
    Last Post: December 30th, 2010, 10:50 AM
  3. Features Roadmap
    By Happy Jim in forum FlashScan V2
    Last Post: July 30th, 2008, 11:32 AM
  4. 2-bar roadmap
    By mistermike in forum General (Petrol, Gas, Ethanol)
    Last Post: June 28th, 2005, 05:50 PM
